New Product: Air Cylinders With Piston Sensing
March 20, 2008
The Airpel line of nonstiction air-cylinder actuators feature state-of-the-art giant magnetoresistive (GMR) technology, which is based on the measurement of the average strength of the magnetic field.
GMR sensor chips reside in a plastic shell with a small LED window for visible indication of the switching signal.
For applications requiring electrical output of piston position, an optional switch-activating magnet on the piston, as well as one or more 9.51 6.83-mm aluminum tracks that attach to the cylinder are available.
The sensors operate at 10 to 30 Vdc with ±0.2 mm repeatability.
Airpot Corp.
35 Lois St.
Norwalk, CT 06851
(800) 848-7681
airpot.com
Dec. 23, 2024
Dec. 23, 2024
Dec. 23, 2024
Dec. 20, 2024
