Electronic Position Sensor For Cylinders
Sept. 28, 2006
A new electronic position sensor for cylinders targets gripping, clamping, and part-selecting applications.
The unit continuously monitors the position of a cylinder piston within a range of 50 mm. Installation is straightforward: insert the sensor into the T-slot and lock the unit in place with an Allen key.
Festo Corp., 395 Moreland Rd., Hauppauge, NY 11788, (631) 435-0800, www.festo.com/us/sensors
