Metal Case
May 10, 2007
The FreeTEC versatile case is designed with a self-supporting inner frame and a decorative outer shell.
The FreeTEC versatile case is designed with a self-supporting inner frame and a decorative outer shell. Four screws holding the cover are easily removed for initial assembly, maintenance, and service. Modification such as cutouts and venting are easily incorporated in the all-metal design. Custom colors and labeling are also available.
Polyrack North America, 235 Promenade St., Providence, RI 02908, (401) 228-7699, polyrack.com
Dec. 23, 2024
Dec. 23, 2024
Dec. 23, 2024
Dec. 20, 2024
