New Product: Rotary Tables
July 10, 2008
The RT4 Series rotary table, with a 4-in.-diameter tabletop and a 4 × 5-in. footprint, can carry up to 100-lb loads.
The Series offers 4-arc-min positional accuracy, 0.03° run out, 1-oz-in. breakaway torque with loads of 50 lb, and 1,750-rpm maximum input speed.
Constructed of black-anodized aluminum, the actuator has 303 stainless-steel worm and shafting with a 464 bronze gear and ABEC 7 stainless-steel bearings and thrust washer provide smooth tabletop rotation. NEMA-17 stepper-motor-mount or hand-crank models are standard. Available gear ratios are 45:1, 90:1, or 180:1.
PIC Design
86 Benson Rd., Box 1004
Middlebury, CT 06762
(800) 243-6125
pic-design.com
