Thin Vacuum Conveyor
Feb. 22, 2007
The 2200 Series vacuum conveyor has a frame height of 1.87 in., letting it fit in tight spaces.
Other features include an aluminum extruded frame with T-slot construction, sealed ball bearings, works with V-guided and non-V-guided belts, as well as end or centerline drives, and rack-and-pinion belt tensioning. Widths range from 1.75 in. to 2 ft, and lengths are between 2 and 24 ft. Belt speeds can be up to 264 fpm.
Dorner Mfg. Corp.,
975 Cottonwood Ave., Box 20, Hartland, WI 53029,
(800) 397-8664,
dorner.com
Dec. 23, 2024
Dec. 23, 2024
Dec. 23, 2024
Dec. 20, 2024
