Based on the NC Kernel software platform, the TNC 620 uses intelligent motion control with dynamic look-ahead and jerk limitation algorithms. The main computer is housed inside the operating panel behind the TFT flat-panel display, eliminating complicated wiring into the electrical box. When used with an EnDat 2.2 encoder, the system is uniformly digital from the main computer to the encoder.
Heidenhain Corp., 333 E. State Pkwy., Schaumburg, IL 60173, (847) 490-1191, heidenhain.com
Dec. 12, 2024
Dec. 12, 2024
Dec. 12, 2024
