Static Rod Lock
Nov. 4, 2004
The Static Rod Lock is a spring-engaged, air-released unit designed to clamp and hold cylinder rods and shafts up to 1.375 in.
The is a spring-engaged, air-released unit designed to clamp and hold cylinder rods and shafts up to 1.375 in. They can be used stand-alone or mounted on ISO and NFPA cylinders with rod diameters of 16, 20, 25, and 32 mm and 0.625, 1.0, and 1.375 in. They feature 0.000 to 0.003-in. backlash, high clamping force, and accurate holding. IP67 washdown compliant and rated for more than 3 million cycles, the rod locks are suitable for highaccuracy holding or general-purpose machine-tool, packaging, material-handling, food-processing, and injection-molding applications.
Nexen Group,
560 Oak Grove Pkwy., Vadnais Heights., MN 55127,
nexengroup.com
Dec. 23, 2024
Dec. 23, 2024
Dec. 23, 2024
Dec. 20, 2024
