Linear Positioners
Dec. 8, 2005
HD Series linear positioners are said to be easily applied, installed, and maintained.
The deep-channel extruded body and solid carriage provide beam strength and carriage stiffness, which suits cantilevered or other unsupported installations. The linear bearings and ball screws are self-lubricating precision components designed for long life at 100% duty operation with no maintenance. The HD Series also includes IP30-rated belt seals that protect the interior components from debris in factory environments. As part of the configurable part number, users can select options such as screw lead, home and limit sensors, a fail-safe brake, and motor orientation.
Parker Hannifin Corp., Electromechanical Automation Div., 1140 Sandy Hill Rd., Irwin, PA 15642, (800) 245-6903, phdaeda.com
Dec. 23, 2024
Dec. 23, 2024
Dec. 23, 2024
Dec. 20, 2024
