Machine-Vision Camera
March 9, 2006
The CS6910CL machine-vision camera uses a Fuji honeycomb, 1 /4-in.-CCD sensor for low error rates and speeds up to 30 frames/sec.
The CS6910CL machine-vision camera uses a Fuji honeycomb, 1 /4-in.-CCD sensor for low error rates and speeds up to 30 frames/sec. The sensor receives SXGA or VGA images in 24-bit color, even in random trigger shutter. A Camera Link interface lets users work with new or existing vision systems. The camera weighs 150 gm and is a compact 54 X 43 X 59 mm. It operates on 12-Vdc power.
Toshiba Teli America Inc., 33 Hammond, Suite 211, Irvine, CA 92618, (949) 770-8354, toshiba-teli.com
Dec. 20, 2024
Safety Products Overview
Dec. 20, 2024
Dec. 20, 2024
Dec. 20, 2024
