Single-Axis Controllers
Sept. 14, 2006
The SMLC-SA single-axis controller reduces wiring, panel-space requirements, and programming efforts.
It is scalable from one to 16 axes. The CoDeSys Integrated Development Environment and runtime engine offer extensive diagnostics. ServoWire Pro, a suite of configuration, tuning, diagnostic, and maintenance utilities, assists in commissioning drive. This controller's power ranges from 600 to 24,000 W or 30+ hp, and input voltages can go from 115 to 480 Vac. It has program logic and can handle motion using all five IEC 61131-3 languages. Two Ethernet and two serial ports are included.
Ormec Systems, 19 Linden Park, Rochester, NY 14625, (800) 656-7632, ormec.com
