Fastening System
Oct. 12, 2006
The painted Fas-Ner System is a simple punch-and-die operation that automatically feeds, punches, inserts, and locks the self-piercing Fas-Ner to produce a solid joint in one high-cycle operation.
An alternative to spot welding and riveting, the system can also join dissimilar metals and thicknesses. The color of a Fas-Ner is matched to the color of the painted assembly, eliminating postpaint operations. Systems range from a single hit machine to complex machines, such as an automated turnkey system, including insertion into main production lines with the assistance of machine integrators.
AKH Inc., 2830 S. Lyndhurst Dr., Indianapolis, IN 46241, (317) 243-5915, akhfas-ner.com
Dec. 12, 2024
Dec. 12, 2024
Dec. 12, 2024
Aug. 29, 2024
