Low-Friction Bearing Materials
June 16, 2005
Dynaglide 600 bearing and seal compounds reduce friction and wear in dynamic use, dry or wet.
They come in 10 distinct film grades to help maximize efficient mating with different surfaces in different environments. They come in 0.500 to 24.0-in.-wide rolls and 0.010 to 0.064-in. thickness. They can be pretreated for bonding or coated with pressure-sensitive adhesives. Custom washers, rings, U-cups, and other die-stamped shapes are also available.
DeWAL Industries, Inc.,
15 Ray Trainor Dr., Saunderstown, RI 02874,
(401) 789-9736,
dewal.com
Dec. 12, 2024
Dec. 12, 2024
Dec. 12, 2024
Aug. 29, 2024
