They require only two bolts to provide compact, leak-resistant flange connections. The adapters mate with either of two diagonal-tapped mounting holes of the same nominal size SAE Code 61 4-Bolt flange port. Their small footprint lets adjacent ports be nested more closely and efficiently. The two-bolt flange mounting holes may be oriented 360 about a central fluidflow axis for maximum flexibility in designing hydraulic components and systems. They are available in 0.125 to 2-in. sizes. Industry-standard sockethead cap screws are used to assemble the flanges, and they meet or exceed strength requirements of ASTM Standard A574 (minimum tensile strength of 180,000 psi).
Adaconn,
538 Township Line Rd., Blue Bell, PA 19422,
(215) 643-1900, www.adaconn.com
