CAM Software
Aug. 18, 2005
The latest version of Esprit CAM software includes a package for programming multitasking mill-turn machine tools.
It eliminates the need for users to devote time to postprocessors and machine definition, formerly routine steps made increasingly complex by multitasking machine tools. Real-time simulation verifies machining processes without taking machines off-line for expensive dry runs, leaving programmers confident of the results prior to cutting parts. Multitasking machining can reportedly increase productivity by up to 400%, compared with using different machine setups. The factory-tested software is for programming machines from Mori Seiki, Nakamura Tome, Citizen, EMCO Maier, Mazak, and others.
DP Technology Corp., 1150 Avenida Acaso, Camarillo, CA 93012, (805) 388-6000, dptechnology.com
Sept. 16, 2025
Sept. 16, 2025
Sept. 16, 2025
