Oneinch repeatable mounts handle up to 2,000 lb/connector (6,000-lb total) compared with about 20 lb for conventional sphere-based designs. Applications include the elimination of recalibration in heavy removable components, aligning instruments subjected to dynamic loads, and optical instruments sensitive to warping under mount loads. The connectors come in stainless steel, tungsten carbide, high-temperature ceramics, and engineering plastics.
g2 Engineering,
725 N. Shoreline Blvd.,
Mountain View, CA 94043,
(650) 605-4500,
g2-engineering.com
