Efficient gear technology contributes to high push-force capabilities and reduced noise levels. The columns incorporate a 24, 120, or 230-Vdc linear actuator to extend or retract its three telescopic aluminum profiles. Maximum operating speed, with minimal vibration, is 45 mm/sec. Stroke lengths up to 700 mm are possible. Safety features of the columns include self-lock in push and pull, integrated limit switches, cutoff switches, and a backup nut at the end position.
SKF Actuation Systems, 1530 Valley Center Pkwy., Bethlehem, PA 18017, (800) 541-3624, linearmotion.skf.com
Dec. 23, 2024
Dec. 23, 2024
