Pipe-Mounting
Aug. 5, 2004
Stackable pipe-mounting collars feature nylon bushings to compensate for thermal expansion and vibration.
PIPE-MOUNTING COLLARS
The collars are twopiece designs with flats on both outside surfaces, which are drilled and tapped to attach to each other, and have a countersunk hole for mounting to any surface. The nylon bushings are split to easily fit into the pipemounting collars. Bushings are offered in six pipe sizes with one or two flanges. In addition to nylon versions, the collars are available in aluminum, steel, and stainless steel and can include a finished OD. Optional PTFE bushings can also be supplied.
Stafford Mfg. Corp.,
Box 2370, Woburn, MA 01888,
(800) 695-5551,
www.staffordmfg.com
Jan. 23, 2025
Jan. 17, 2025
Jan. 17, 2025
Jan. 17, 2025
