Industrial Programming Tool
Sept. 2, 2004
New 759-333 WAGO-IO-PRO CAA (CoDeSys Automation Alliance compatible) programming software for the Wago 750 Series of Programmable Fieldbus Controllers (PFC) and the 758 Series Industrial PCs (IPC) is fully compliant with the IEC 61131-3 open-programming standard.
The 759-333 programming tool can help program/configure hardware from other Automation Alliance Partners, i.e., drives, motion controllers, etc. Key features include complete offline simulation, editors for programming in instruction list, sequential function chart, function block diagram, structured text, ladder diagram and continuous function chart languages, visualization elements, library management for user-defined libraries, and code generators for the most common industrial CPUs and controllers. There's no need to purchase hardware or software keys for operation.
Wago Corp.,
N120 W19129 Freistadt Rd., Germantown , WI 53022,
(800) DIN-RAIL, www.wago.com
Dec. 23, 2024
Dec. 23, 2024
Dec. 23, 2024
Dec. 20, 2024
