Jewel bearings comprise the motors bearing system. The 3 x 8-mm motor weighs 0.33 gm. The device outputs a continuous torque to 0.014 mNm at speeds to 15,000 rpm. For a complete miniature-drive system, the motor can be combined with a gearbox and linear actuator. An available 3-mm-diameter plastic planetary gearhead with various reduction ratios allows for continuous output torque up to 0.88 mNm and 1.32 mNm in intermittent operation. The linear actuator consists of a M1.6 x 0.2 high-precision leadscrew.
MicroMo Electronics Inc., 14881 Evergreen Ave., Clearwater, FL 33762, (727) 572-0131, micromo.com
Dec. 23, 2024
Dec. 23, 2024
