MDrive Plus
Dec. 14, 2006
The MDrivePlus allows for a wide range of frame-size offerings.
Drive voltages range from 12 to 75 Vdc and 120 and 240 Vac. The housing uses a cast-aluminum heat sink and other chemical-resistant materials. Interface to standard industrial circular connectors and cordsets is available.
IMS Intelligent Motion Systems Inc., Box 457, 370 N. Main St., Marlborough, CT 06447, (860) 295-6102, novantaims.com
