Fuse Holders
Feb. 8, 2007
Subminiature fuse holders allow quick and easy fuse changes in high-density circuit-board applications.
For use with 8.5-mm-diameter fuses, the holder's barrier design protects leads from arcing. Thru-hole mounting secures the holders placement on PCBs and maintains positioning during wave soldering. The bases are manufactured from UL 94 V-0 thermoplastic with gold-plated, beryllium-copper springs and tin-plated brass pins. Low-contact-resistant tension springs increase reliability and ease installation. Holders are available in two Sturdii-Mount designs, a low-profile type, and a space-saving version where components are placed under the holder.
Keystone Electronics Corp.,
31-07 20th Rd., Astoria, NY 11105,
(800) 221-5510,
keyelco.com
