Handheld Pressure Calibrator
April 26, 2007
The handheld Jofra DPC-500 calibrates pressure gages, transmitters, switches, digital manometers, and overpressure-protection valves.
A separate pressure sensor can be fixed to the instrument or connected via cable. Up to five interchangeable reference sensors of different pressure ranges can be used with one instrument. The DPC-500 features an extended pressure range of 250 mbar to 1,000 bar FS, and 15 predefined units (bar, mbar, hPa, psi, in. Hg, cm Hg. MPa, kPa, Pa, mH20, cmH20, mmH20, kg/cm2, in.H20, and mm Hg.). Additional features include a large illuminated display, rechargeable lithium-ion battery, and a menu-driven interface available in five languages. Data can be transferred to Microsoft Excel using DPC-CAL software via the unit's USB and RS-232 interfaces.
Ametek T&CI Americas,
Harriman Business Center, 1220 Washington Ave., Bldg. 7A/Suite 300, Albany, NY 12226,
(518) 689-0222,
jofra.com
Dec. 23, 2024
Dec. 23, 2024
Dec. 23, 2024
Dec. 20, 2024
