Heater Mounts On Walls And Ceilings
Jan. 12, 2006
Model HVH blower heater mounts on walls and ceilings to provide vertical or horizontal airflow in power-generating stations, aircraft hangars, and warehouses, among other applications.
The heater's compact size lets it fit in tight spaces. Features include a pilot light to indicate normal operation, adjustable on and off electronic-fan time-delay control, and outlet screen to prevent objects from contacting the fan. The MHV is UL listed and CSA certified for use in the U.S. and Canada and is CE certified to meet European standards.
Chromalox Inc., 103 Gamma Dr., Pittsburgh, PA 15238, (800) 443-2640, chromalox.com
