The terminal block has spring-clamp terminations and the capability to accept standard blade-type fuses. The fuse comes in a wide range of voltages and currents up to 125 V at 15 A. For troubleshooting and maintenance applications, LED indication is available.
Automation Systems Interconnect Inc., Box 1230, Carlisle, PA 17013, (877) 650-5160, www.asi-ez.com
Safety Products Overview
Dec. 20, 2024
