The inlet port is a 10-32 external thread with an O-ring face seal for leak-tight connections. The outlet port adjusts for easy connections. The device can be supplied in a range of configurations such as tees, elbows, crosses, and manifold mount, as well as a wide variety of connection styles such as tube barbs, compression connections, or push-to-connect connections. The device is fabricated entirely from stainless steel and is available with a variety of elastomeric seals that work with a range of fluids and provide a variety of thermal resistances.
Beswick Engineering Co. Inc., 284 Ocean Rd., Greenland, NH 03840, (603) 433-1188, beswick.com
Dec. 23, 2024
Dec. 23, 2024
