Spherical Roller Bearings
Sept. 27, 2007
The 185-page Spherical Roller Bearing catalog covers the complete line of bearings ranging from 25 to 1,500-cm bore (0.98 to 59.06 in.).
Also covered are spherical pillow blocks and metric spherical accessories, such as adapters and withdrawal sleeves. A comprehensive section focuses on bearing and accessory selection, cage design and determination of applied loads, load ratings, shaft and housing tolerances, mounting, fitting, temperature, lubrication, and seals. Both an interactive and CD version are available.
The Timken Co., 1835 Dueber Ave. SW, Box 6932, Canton, OH 44706, (330) 438-3000, timken.com
Dec. 23, 2024
Dec. 23, 2024
Dec. 23, 2024
Dec. 20, 2024
