Load Sensors Work at High Temperature
Aug. 5, 2004
High-Temperature FlexiForce force and load sensors have been tested at temperatures as high as 420°F.
LOAD SENSORS WORK AT HIGH TEMPERATURE
High-Temperature FlexiForce force and load sensors have been tested at temperatures as high as 420°F. They target demanding applications such as engine gaskets, injection molding, laminates, and other high-temperature processing applications. New A201 Models are trimmable. Users can customize the length of the sensors themselves, or they can be factory trimmed at lengths of 2, 4, and 6 in. for an additional charge. The A201 force sensors are terminated with a male square pin instead of the standard berg connector. This is a much thinner connector and therefore less intrusive.
Tekscan Inc.,
307 W. First St., South Boston, MA 02127,
(617) 464-4500,
www.tekscan.com
Dec. 23, 2024
Dec. 23, 2024
Dec. 23, 2024
Dec. 20, 2024
