NEMA JUNCTION BOXES
Terminal-block rail assemblies are mounted and labeled in the enclosure so installers simply mount the junction box and terminate the conductors. The enclosures are formed from 14-gage, Type-316L stainless steel that contains a watertight and dusttight seal. A removable internal Type-304 stainless-steel panel provides the mounting surface for stainless-steel DIN-rail terminal-block rail assemblies. The J-BOX SST 4X junction-box assemblies are available in four different size enclosures containing a variety of terminalblock-rail assemblies ranging from standard feedthrough blocks to thermocouple blocks.
Phoenix Contact,
Box 4100, Harrisburg, PA 17111,
(717) 944-1300,
www.phoenixcon.com
Dec. 23, 2024
Dec. 23, 2024
