Output pressure, proportional to an electrical command signal, is unaffected by changes in supply pressure. An inlet solenoid valve shifts proportional to flow and maintains system presence. The variableorifice effect controls pressure at low-flow conditions and avoids the digital steps of traditional on/off solenoids. The Series is available in a wide range of electrical command inputs and analog outputs. An IP65 enclosure houses the unit.
Proportion-Air Inc.
Box 218
McCordsville, IN 46055
(317) 335-2602
proportionair.com
Dec. 23, 2024
Dec. 23, 2024
