Electronic Housing System
Dec. 14, 2006
The Building case system is designed primarily for the buildingautomation industry.
It features uniform compact height and allows a variety of PCB-design options in mounting, component height, networking, and termination. It lets PCBs mount in vertical, horizontal, or lengthwise directions. A 16-position DIN-rail connector allows parallel or serial communications and power busing. The housing system complies with DIN 43380 and works with standard terminal blocks and data connections.
Phoenix Contact Inc., 586 Fulling Mill Rd., Middletown, PA 17057, (800) 888-7388, phoenixcon.com
Dec. 23, 2024
Dec. 23, 2024
Dec. 23, 2024
Dec. 20, 2024
