Servomotor Adapter
Aug. 23, 2007
The Model HP servomotor adapter is designed to simplify servomotor mounting.
The Model HP servomotor adapter is designed to simplify servomotor mounting. The adapter features true double-enveloping worm-gear technology. Specifications include 3, 3.5, and 4-in. center distances; up to a 260-mm sq motor frame; 19,160 lb-in. (single-reduction) output torque; 5:1 to 60:1 single-reduction gear ratio and up to 3,600:1 in double reduction; backlash levels from zero to 15 arc-min; and solid, hollow, and shrink-disc output options.
Cone Drive, A Textron Co., 240 E. 12th St., Traverse City, MI 49684, (888) 994-2663, conedrive.com
