New Product: The Smart Connector(tm) UWTC Series
March 20, 2008
Omega's new Wirelss Thermocouple Connector Series features stand-alone, compact, battery powered thermocouple connectors that transmit linearized, coldjunction compensated measurements back to a USB powered receiver connected to a PC.
Each wireless connector unit can be programmed in the field to work as a type J, K, T, E, R, S, B, N or C calibration connector. The Patented universal input accepts both standard and minature size mating connectors. When activated the connector will transmit data continuously at different user selectable time intervals. Up to 12 wireless connectors can be used with a single receiver. The included software program converts your PC into a 12 channel meter, strip chart recorder and data logger. Readings can be saved and later printed or exported to a spread sheet file.
Omega Engineering, Inc.
Dec. 23, 2024
Dec. 23, 2024
Dec. 23, 2024
Dec. 20, 2024
