Southern Graphic Systems
Sept. 15, 2005
Southern Graphic Systems Canada, Toronto, designed Nestlè Canada Inc.'s Coffee Crisp container to resemble a bag of coffee.
Canada, Toronto (alcoa.com), designed Nestlè Canada Inc.'s Coffee Crisp container to resemble a bag of coffee. The base is large enough to support the product on the shelf. Designers printed the graphics on the inside of clear poly laminate to white poly. The construction provides good barrier properties to keep the product fresh.
