New Product: Two-phase motor/driver
Jan. 24, 2008
The RBK two-phase bipolar stepping motor and driver package features dc input and a smooth drive function that divides the basic 1.8° step angle up to 128 ?steps (0.018° step angle) in 16 selectable resolutions using built-in switches located on the driver.
A harmonic suppression function reduces stepmotor torque vibrations by correcting or shaping the driver current waveforms, particularly at lower motor shaft speeds. Another function suppresses the vibration signal levels in the midspeed range. These four control functions provide smooth operation over a wide speed range. The driver’s constant-current-drive strategy operates over a 20 to 75-Vdc range. Effective current reaches 6.3 A peak (4.5 A RMS) per phase.
The system comes in two stepmotor frame sizes, each offering three models. The first Series includes the RBK264A, 266A and 268A with holding torques ranging from 68 to 240 oz-in. The RBK296, 299, and 2913, have holding torques of 310 to 910 oz-in.
The second Series, the IP65-rated motor package, has the same two frame sizes (RBK264T and RBK296T) and three models each with similar holding torques.
Oriental Motor USA Corp.,
1001 Knox St., Torrance, CA 90502,
(800) 418-7903,
orientalmotor.com
Dec. 23, 2024
Dec. 23, 2024
Dec. 23, 2024
Dec. 20, 2024
