Digital Pressure Gage
April 27, 2006
The AccuGauge digital pressure gage works with gas, liquid, or solid media that are compatible with 17-4 PH stainless steel.
The gage targets applications requiring high proof and burst pressures. Its steel sensing element has no welds, internal O-rings, or fluid-filled cavities, and a rugged NEMA-4, IP65, polycarbonate body houses the transducer. The gage measures in psi, bar, and kg/cm 2 , among other units, and is vacuum calibrated for pressures under 500 psi. A large, four-digit LCD shows measurements.
American Sensor Technologies Inc., 450 Clark Dr., Mt. Olive, N.J. 07828, (973) 448-1901, astsensors.com
