Controllers Simplify Tough Jobs
Aug. 5, 2004
The 3508 (1/8 DIN) and 3504 (1/4 DIN) controllers are built for demanding, high-accuracy, single-loop control applications.
CONTROLLERS SIMPLIFY TOUGH JOBS
They rely on advanced control algorithms and high-resolution inputs, which give virtually “straight-line” control. To make them easy to use, a text-message display is supported by configuration software. This lets users know the exact name of parameters being set and lets them save time commissioning the unit. A manual is no longer needed as a reference. Users can customize the text on the controller for English, French, or German.
The units can be programmed from front-panel IR connections without disturbing controller operation. The device stores up to 50 setpointprograms, each of which can provide control sequencing. Because these controllers incorporate a number of standard function blocks, they can replace a number of other process-control components such as timers, programmable controllers, and single-loop temperature controllers.
Eurotherm,
741-F Miller Dr., Leesburg, VA 20175,
(703) 443-0000,
www.Eurotherm.com
Sept. 16, 2025
Sept. 16, 2025
Aug. 22, 2025
