MINI CIRCUIT BREAKERS
The QLs are hydraulic magnetic MCBs, therefore they do not require the temperature variation compensation associated with most thermal breakers. The devices operate in temperatures from 40 to 140°F. The QL is suitable as a replacement for low-current fuses and a wide range of equipment protection.
Circuit Breaker Industries Inc., 35 E. Uwclan Ave., Suite 328, Exton, PA 19341, (610) 524-9949, www.cbi.co.za
