The sensors are constructed of corrosion-resistant nickel alloy and withstand temperatures up to 700°C. Isolated case construction provides electrical isolation, which is said to help deliver accurate wideband pressure data. Each sensor incorporates a 2-in. integral hard-line extension with a standard 10-32 connector, differing only in their mounting configurations.
Columbia Research Laboratories Inc.,
1925 Mac Dade Blvd., Woodlyn, PA 19094,
(800) 813-8471, www.columbiaresearchlab.com
Aug. 29, 2024
Aug. 28, 2024
