Heavy-Duty Cartridge Valve
June 7, 2007
New TDP 2/2-way electrohydraulic cartridge valves broaden the line of TDA and TDL Series valves for industrial applications.
New TDP 2/2-way electrohydraulic cartridge valves broaden the line of TDA and TDL Series valves for industrial applications. The TDP is a throttle valve with active control and position monitoring. A key feature is the DFplus NG6 with voice-coil drive, which serves as the pilot valve. It reportedly provides precise control with high dynamic performance to the secondary or main stage of the TDP cartridge. This permits high flows in both directions. The valves are said to increase efficiency and reduce cycle times through high dynamic response, and high resolution and precision can enhance product quality. And the robust, proven design reduces downtime.
Parker Hannifin, Hydraulics Group, 6035 Parkland Blvd., Cleveland, OH 44124, (216) 896-3000, parker.com
