The resulting mechanism has low inertial forces for fast accel/decel, and the overall center of gravity is relatively low. These four-axis devices are fully programmable and work at rates normally associated with camdriven mechanisms.
The ductile cast-iron base houses three of the unit's four motors. The work envelope accommodates homogenous and mixed palletizing as well as high-speed conveyor-tracking applications. A payload capacity of 40 kg and a reach of 2,091 mm support both 800 and 1,000-mm pallets.
Kuka Robotics Corp., 22500 Key Dr., Clinton Township, MI 48036, (586) 569-2082, kukarobotics.com
Jan. 10, 2025
Jan. 10, 2025
