Termination options include solder, cable, and fast-on connectors. They are wound on flat cores rather than cylinders and are housed in flat-aluminum extrusions 12.6-mm high. Heat is spread through the wide aluminum baseplate to the heatsink. The resistor can be tapped, a feature not available in MIL-R-18546-type resistors.
Ohmite Mfg. Co.
1600 Golf Rd., Suite 850
Rolling Meadows, IL 60008
(866) 964-6483)
www.Ohmite.com
Jan. 10, 2025
Jan. 10, 2025
