Virtual connectors make it easy to perform complex assembly analyses without modeling connectors. And nonlinear loads can be defined by dragging and dropping from linear static studies. For errors, a What's
Wrong function advises if loads, restraints, and meshes are valid. The program works with most CAD systems.
Structural Research & Analysis Corp., 3000 Ocean Park Ave., Santa Monica, CA 91423, (310) 309-2800, cosmosm.com
Jan. 10, 2025
Jan. 10, 2025
