Liquid-Level Indicator
Feb. 8, 2007
The VLIT is an all-stainless-steel magnetic level indicator with a twin capacitance transmitter that provides high-resolution 4-to-20-mA or 0-to-5-Vdc output.
High-contrast color flags in the external indicator channel flip to their color side as the magnetic ball float passes. Mounted in a separate stainless-steel chamber, the transmitter operates independently of the indicator float for a truly redundant measurement system. Options for the VLIT include separate point-level switch outputs for alarm and valve-control functions, integral isolation valves, and custom scales and colors.
Innovative Solutions,
60 Great Hill Rd., Naugatuck, CT 06770,
(203) 729-6434,
innovativesensing.com
