Colorimeter tests that measure the amount of color and light able to pass through plastics showed the SL resin was as transparent as high-clarity acrylic and polycarbonate sheet. The resin’s clarity is also on par with that of milled acrylic in both thin and thick sections. In the event secondary finishing is needed, the SL resin sands easily and can be clear coated.
DSM Somos, 1122 St. Charles St., Elgin, IL 60120, (847) 697-0400, dsmsomos.com
Dec. 23, 2024
Dec. 23, 2024
