The new version supports Profibus, DeviceNet, and CANopen, as well as the company’s Drive & Diagnostic Link. The CL03 Series is suited for areas where direct contact with food is possible, as well as on machines that require high-pressure, high-temperature cleaning. The polymer cover resists harsh chemicals, and the hygienic design without seams or gaps prevents dirt accumulation. And the IP69K-rated unit mounts directly on equipment and does not require a control cabinet. The CL03 incorporates up to 16 valves with flows of 0.7 to 0.85 Cv (700 to 850 lpm.)
Bosch Rexroth, 1953 Mercer Rd., Lexington, KY 40511, (859) 259-3852, boschrexroth-us.com.
Aug. 29, 2024
Aug. 28, 2024
