Oval Rocker Switch
June 7, 2007
A Series of oval rocker switches come in single-pole and double-pole versions with UL, cUL, and VDE approvals.
The RL3-6 Series is a single-pole switch is UL rated at 16 A for 125 Vac or 13 hp at 125 Vac for high-power and motor applications. The YSR-34 is a DPST switch rated at 16 A for 125 Vac or 12 hp at 125 Vac. The rocker can hold red, green, or amber lighting and both standard and custom markings are available.
Phaseda LLC, 11080 S.W. Allen Blvd., Suite 300A, Beaverton, OR 97005, (503) 564-4647, phaseda.com
Jan. 10, 2025
Jan. 10, 2025
Jan. 10, 2025
Jan. 10, 2025
