Labor and assembly costs are eliminated as well as the potential for crimping or shorting LED leads. The nylonmolded mounts control heights from 0.120 to 0.925 in. with 0.020-in. bosses. Universal black-nylon-molded spacer mounts, in 0.120 to 0.925-in. lengths, accommodate both Tri-Lead and Bi-Lead LEDs. These mounts have the ability to separate and retain component leads to facilitate PCB mounting and accommodate uses for lamps, resistors, transistors, diodes, capacitors, and other components.
Keystone Electronic Corp.,
31-07 20th Rd., Astoria, NY 11105,
(800) 221-2017, keyelco.com
Jan. 10, 2025
Jan. 10, 2025
