New Product: Pressure/vacuum transmitter calibration connectors
May 8, 2008
The MIT-TM TwistMate calibration connectors feature “twist-to-connect” action that provides a leaktight connection without thread sealants or wrench tightening for vacuum or pressure testing to 2,500 psi.
The ergonomically designed connector eliminates wear and thread damage from repeated connections. An internal swivel permits easy installation while connected to a supply line. The devices are designed for connecting to recessed …-in. NPTF transmitter manifold ports and …-in. side manifold ports. Sizes range from 1/8 to -in. NPT.
FasTest Inc., 1646 Terrace Dr., Roseville, MN 55113, (800) 444-2373, fastestinc.com
Aug. 29, 2024
Aug. 29, 2024
Aug. 28, 2024
Aug. 28, 2024
