New Product: Hollow Shaft Brushless DC Actuators
Nov. 21, 2007
Hollow Shaft Brushless DC Actuators feature a through-bore up to 14 mm in diameter and provide high torque and exceptional positioning accuracy.
This performance is achieved in a compact design using a high performance harmonic drive coupled to a brushless DC motor and a high resolution encoder. Maximum torque up to 250 in-lb and positional accuracy better than 1.5 arc-minute can be achieved. The FHA Mini Series is available in 3 frame sizes, ranging from 50 to 75 mm square, and 48 to 66 mm in length.
