Mini-ITX PC Systems
Jan. 26, 2006
Series of industrial PC systems offer a wide range of processing and I/O options and can work as a desktop or benchtop, or wall mounted for more secure applications.
The Impact-R 150 The units are in the 11 10.5 2.6-in. mini-ITX form factor. The Impact-R 150 is designed for harsh environments and features long-life motherboards with extensive burn-in testing of each unit before delivery. The stainless-steel units work in 5 to 50°C conditions, have two front USB 2.0 ports, and can take a PCI expansion board internally. CPU options range from 1-GHz Eden processors to 2.8-GHz Pentium 4s.
Saelig Co. Inc., 1160-D2 Pittsford-Victor Rd., Pittsford, NY 14534, (585) 385-1750, saelig.com
